Hooking up more case fans? (Corsair Carbide 88R)
skoshea
Hi there! First off, I apologize if this is in the wrong place. First time making a post here.
Recently finished building my first PC. Built it in a Corsair Carbide 88R, which came with one 120mm fan already installed right above my GPU. Apparently, the case can support up to four more 120mm fans, but the motherboard I bought (MSI H110m pro-vd) only had one sysfan header, which is where I put the included fan. My PC gets pretty warm during certain games and that's.. Worrying. I stuck with the stock Intel cooler since I won't be overclocking, so I'm not too sure if that's the big issue here, but I figured only having one case fan blowing hot air out wasn't quite cutting it. Getting some proper airflow would certainly help keep things cool, right?
My question is, is there a way I can power four more fans without using my mobo?
My PSU has a molex connector, which I believe I understand can be used to power up some case fans, but, do I need to purchase some adapter that has enough 2/3 pin connectors for the fans?
Is there even such an adapter that has 4 separate connectors?
I had my eyes on this little bundle, in the way of fans - https://www.amazon.com/dp/B000O8I474/_encoding=UTF8?coliid=I216A2INK742KL&colid=291NNVLWPX8DU
I can give more information if it's needed. Thank you for reading!
Buy 2 more fans and mount them as intake in the front, it will probably be enough. Those two you can connect through a 3 pin to molex adaptor but keep in mind that if you connect them through molex you will not be able to control the speed of the fans.
Huh. Alrighty then. That works for me, I already can't control the one fan I have. That was also a 3 pin.
I'll only need one 3 pin to molex adapter for two fans? Pretty sure I only have one molex cable.
Sorry, still quite the neophyte PC builder.
Thanks for the help!
You should be able to control that fan through BIOS.
No, a typo by me. You will need a molex to 2x3 pin or more. Like this for example: https://www.amazon.com/ExtremeMod-Computer-Connector-Y-Splitter-Adapter/dp/B00DU8ZZ0O/ref=pd_sim_147_2?_encoding=UTF8&psc=1&refRID=QEEEVGYKDANVZ4ST008R
If you dont mind the noise then you can buy high rpm fans. If you mind the noise then you must buy low rpm fans.
