Hey guys, total hardware newbie here. Big car guy. Owned a 2006 Infiniti G35 for around 8 years now for 100k miles and still grabbing the groceries quick.
I'm looking for something newer on a new platform, PC Gaming. Much more affordable if you look at the big picture... I digress. I am hoping to convert my parents old dead HP Pavilion into my low-medium graphics HIGH FRAMERATE gaming PC. Ill add a picture to the end. Let's just call this a sleeper model PC
. This PC will also be used for office Professional and Photoshopping to make my friends wives look better for them.
So you guys have a form, I'll follow it. Thanks ahead of time for your responses. I was pointed this way from a friend in my college of engineering. Side note, current setup (I don't know if the drivers for the AMD processor are even set up correctly...) plays Skyrim at 1 fps on minimum graphics and The Sims 3 at 20 fps, why?
In order to make things easy, copy and paste the following template into your post and edit the italicized examples to suit your needs:
Approximate Purchase Date: Anytime, I have the money "I HAVE MICROCENTER"
Budget Range: 500$ ALL IN Before Rebates?
System Usage from Most to Least Important: Gaming, photoshop, office documents
Are you buying a monitor: No, LG Flatron W2361V (1920x1080)
Parts to Upgrade: CPU, Graphics Card?, MOBO, Power supply (currently Inland 400W [Obvs need to upgrade]), Fans?
Do you need to buy OS: No, HDD has 8.0
Preferred Website(s) for Parts: Newegg if it has to be online, microcenter is a mere 10 minutes away (its cold and dark outside, but I guess I could venture out if it would help me venture Skyrim).
Parts Preferences: Any, I want the best value that will get me the low-medium at high FPS.
Overclocking: Maybe (only for gaming)
SLI or Crossfire: Microcenter tells me crossfire
Your Monitor Resolution: 1920x1080 64 hz?
Additional Comments: I mean no one can complain about a lack of noise. I will be running The Sims 3, Skyrim, Civ 5, BF4 (Free from AMD, doesnt work with current settings :[ )
And Most Importantly, Why Are You Upgrading: Xbox bores me, my car is costly in track maintenance.
Include a list of any parts you have already selected with descriptively labeled links for parts. Please do not post only links.
A10 7850K 4.0 GHz Black Edition Boxed processor For $129.99
A78M-E45 FM2 mATX AMD Moterboard For $29.99 (Deal with AMD Processors)
Ballistix Sport 8GB DDR3-1600 (PC3-12800) CL9 Dual Channel Desktop Memory Kit (Two 4GB Memory Modules) $64.99 (Crucial Special)
Silver Series ILS-400-2 400 Watt ATX Power Supply $29.99
Stock Shell & Other cables, Stock fans (1 at south of CPU), stock front panel, etc. (Ask if something is missing.
What could I do to make this system get to my requirements? (Those are low-medium settings with HIGH FPS) I currently get 1 fps on skyrim and 20 fps on the sims 3. If i bought a bad combo, I would like to know, just got these 2 days ago b/c its what the microcenter rep said would be good. Feel free to call me an idiot for trusting him if the parts are dinosaured together, I trust you guys to make the best decision. What should I do?
THANK YOU!!!!
THANK YOU!!!!
