C crazyladynboyz Prominent Nov 30, 2017 1 0 510 Nov 30, 2017 #1 Is a wifi range extender able to be used with a hot spot device? Would it help any if so?
Solution Ralston18 Dec 1, 2017 Yes. And an extender can help but performance may become an issue. Here are two links to provide some guidelines: 1) To address the overall concepts and keep the terminology constant: https://www.intel.com/content/www/us/en/tech-tips-and-tricks/what-is-a-hotspot.html 2) To address more of the details and possible product choices: https://www.tomsguide.com/us/best-wifi-extenders,review-2225.html Use the information from both links to assess your intended implementation. Plan it out and post your ideas and plans. Someone may spot some issue or other error of omission or commission.
Ralston18 Titan Moderator Oct 11, 2014 39,496 4,420 146,290 Dec 1, 2017 Solution #2 Yes. And an extender can help but performance may become an issue. Here are two links to provide some guidelines: 1) To address the overall concepts and keep the terminology constant: https://www.intel.com/content/www/us/en/tech-tips-and-tricks/what-is-a-hotspot.html 2) To address more of the details and possible product choices: https://www.tomsguide.com/us/best-wifi-extenders,review-2225.html Use the information from both links to assess your intended implementation. Plan it out and post your ideas and plans. Someone may spot some issue or other error of omission or commission. Upvote 0 Downvote Solution
