Hi,
My plan is to put a horizontal PC case to this hole:
So I'm looking for the horizontal PC case that will support:
- front intake 140mm fans (140mm is preferred but 120mm can be too) with dust filter
- back 140mm fan (140mm is preferred but 120mm can be too) for output hot air (with optional dust filter too)
- front optionally should have the possibility to add at least 280mm or longer radiator for water cooling.
- the case must be working in horizontal mode
- it could be nice if I have in front power button and some usb 3.0 ports.
- should fit into this hole and occupy as much space as possible
- should support micro-atx and mini atx
- should support normal atx power supply with length at least 180mm
- the case should have maximized height so I can put on my CPU high cooler
Any advices?
Any advices?
