'Hot Coffee' Question...
  • Thread starter Thread starter Guest
  • Start date Start date
G
Guest
Guest
Archived from groups: alt.games.grand-theft-auto (More info?)
Seeing all this talk about the Hot Coffee Mod... I decided to download
it and check it out but the instructions say you have to start a new
game...
Is there anyway around this cause I don't feel like starting the game
from the beginning again and going through all the missions to finally
get to the Burning Denise mission...
Anyone have a saved game or location where I can download a saved game
so I can see what the Hot Coffee mod deal is all about?
Thanxs...
http://homepage.ntlworld.com/bryan.stevens1/gtasa/saves/
> game...
You don't. Just load a game, CTRL+ALT+DEL back to the desktop, run
sacensor.exe and tell it to remove the censor flag, then ALT+TAB back
to the game.
Mark
I have noticed that with the censor flag off, the wobbling of the
screen during "coffee" is considerably exaggerated, this may be because
I had the censor flag on then turned it off again, and it has left some
corruption in the save file somewhere. You should be safe to run
sacensor.exe and then just quit the game afterwards without saving.
You can also run sacensor.exe with a parameter that is a save file (you
can drop the save file on the exe in explorer to do this) and it will
flip the censor flag in the save file. Make a backup first and you
should be safe this way too.
Phil Hibbs.
>>> game...
>>to the game.
>> Mark
I might have the wrong file then cause I downloaded the file and it
was zipped and the only thing inside was a file called
hotcoffe_main.scm and a .txt file saying:
Hot Coffee Mod for GTA San Andreas by PatrickW
Install:
*Backup your data/script/main.scm file
* Rename hotcoffee_main.scm to main.scm, and replace the original
main.scm with it.
* Start a new game (old savefile will no longer work
* Go to one of your girlfriends, date her en take her home
This mod is rated 18+
Where can I find this sacensor.exe file?
