Hello,
First water cooled built I have ever built. I followed Linus' video https://www.youtube.com/watch?v=JtHDqdo5pR0 .
It is amazing how well the videos stay relevant, so thank you Linus .
I have the Corsaid 900D, the exact pump he used (MCP 655 Swifttech), a 9900K and 2x RTX 2080ti's with an Auros Master board.
The temperatures, under huge overclock, are AMAZING for my gpu's. They never go above 48 degrees. However, my CPU hovers around 85 (in 3 cores, probably closer to 76 in the others) when I prime 95 test it. Idle is like 25-30 degrees. When I game it is around 54 - 60 degrees. This is when it is not overclocked and at a 1.2V (stock). I cannot seem to get a stable overclock at all, and if I do and volt it to 1.275 it gets to around 95 degrees in some cores.
I have an EKWB velocity waterblock. I have 2 480 rads, 1 240 and 1 120. It goes Resovior --> Pump --> 480 rad --> 480 rad --> cpu --> 120 rad --> gpu 1 --> gpu 2 --> 240 rad --> res. The first 480 is in the basement, then the next it up top, then the 120 is in the top back of the case. The last 240 rad is in the bottom accrose from the 480.
I have bleed the air out for some time, and when I put it sideways, cpu facing up and run the pump it seems to work the best for bleeding. I cannot really see liquid moving through the loop, as I stupidly bought a full metal CPU block that isn't see through.
Questions:
Is the system not bled enough?
Is the pump even working? I cannot tell if liquid is moving through, BUT the GPU temps are so good so I assume it is.
I remounted the cooler for the cpu 3x now. Maybe it is just a weird fit and doesnt work with the board that well.
The i9 9900K can't be cooled much better.
Any help would be GREATLY appreciated! Thanks so much, this has been bothering me for so long.
Questions:
