Hot GPU help please
BadAtComputerss
38
I was playing CSGO offline for about an our when my computer shut off. I took the cover off and it was very very hot. I have 6 fans. 3 output (2 on top and on top back) 3 input (one on the bottom and 2 on the front) There are wires from the power supply blocking the left of the bottom fan but noy very badly. How can I speed the fans up. How do I keep things cool? (Its for sure not my cpu)
Case: Corsair Carbide Series SPEC
http://www.amazon.com/gp/aw/d/B00I0MKMG2#Ask (everything is installed)
http://www.amazon.com/XFX-Dissipation-1050MHZ-Graphics-R9-390X-F28M/dp/B00ZFNDQ76/?tag=logicaincrem-20
Check which fans are plugged into which case fan headers and modify the speeds in BIOS. If you mobo has a utility to control fans, then use that. If not, use a method that runs off of system temp or load percentage.
PS- Bottom fans would be better served as outputs than inputs. There is restricted area which the fan can pull from. It can always push air already in the case out.
