No esata on the mobo. I'm as puzzled as everyone else. The sata cables go from ssd to mobo. I was going to post pics but all they show is no ps at ssd. Strange?it is unusual for sure
I can find one example from the past. Does motherboard have Esata? looking around it seems it doesn't.
SSD working without power cable
I can't find anything about this anywhere, so I figured I would ask. I have a crucial mx100 512GB SSD that I have been using for over a year. It has never given me any trouble and has worked perfectly. The only thing is, I just realized that I never connected the power cable to it from my...forums.tomshardware.com
some sata cables can supply power. But they seem to have a molex connector on one end... not a normal sata cable. https://tripplite.eaton.com/products/sata-cables-and-speeds-compared
curious.
It's not possible. Remove the SATA data cable and tell us if you still see the SSDs.They are working fine. I can use all the software and music production for the piano. This is so strange. I have been building for about 30 years & by mistake found this & still don't understand how it's possible.
La Fong I meant it works just like my HDD's. They show in disk management also.
