adarc8 :
Roland Of Gilead :
well, if Geforce Experiencing it is causing the freezes then, at least you have that sorted
ON the ram thing. If it were me, and I had the choice, i'd take the 2400mhz ram and OC. To pay nearly double the price for 3000mhz ram would be like wasted money to me. Havign 16gb will serve you well for AAA gaming, where more system ram is being used. BF1 for example use over 9.1gbs on my system whilst playing. Okay,not all of that is atributable to the game, but you see where it's going!? More resources will help.
Good luck with the choice. Happy gaming
okay mate so ill go for it by your advice, do u think we can oc it to 3000 or only 2733 like urs?
thats a very good question. OC'ing ram is not guaranteed much like CPU's/GPU's. With that said I think most DIMMS can go one strap higher with no increase in voltage, and maybe a second or third, with a voltage increase. So yes, it's possible. For sure. But keep in mind, it's a trial and error type thing. In the same way you are testing your CPU for stress loads etc, you will need to do that with your ram DIMMS too. Different apps to do it, and it's easy enough. But like a CPU overclock, you wanna make sure the ram is stable too. Don't want those BSOD's springing up randomly
PM me for more info if you need. Have a look at some vids for OC mem on your mobo, so you can prepare for the OC attempt. But, it's relatively straight forward, as long as you stick to doing it right.
Although mine is running at 2733, i think it can go more. I just haven't really had the time to push them and test, but will do. My objective is to get to 2933 with about 1.35v, but probably very loose timings. Then once I have it stable and tested, I'reduce the timings to improve the bandwidth.
