Ethernet 1Gbs. All things being done right, you should have a max speed of 1Gbs. Quality of the wiring, routers/switches/etc will affect the actual speed. You need Cat5e or Cat6 to get gigabit speeds.
802.11 Wifi. There are a bunch of them. AC, the latest spec, has a theoretical max of 1.3Gbs. If you can find a real world environment where this happens, also look for a unicorn, they'll be in the same room. Client antenna hardware, router hardware, walls, people, piping, trees, interfering signals from other devices, they all play a part in the signal strength. In general, always slower by a large degree than Ethernet.
USB 3. It's rated to 5Gbs, 10Gbs for 3.1, but thats for ideal data speeds. Network adapters tend to be far less. I've only seen them rated to around 800Mbs ish speeds.
USB-C, which is basically USB 3.1. For networking, you'll run in to the same problems as USB 3, it'll all depend on the adapter you use.
