How big of a power supply do you really need?
gamerx456
35
I'm building a cheap gaming rig for around $700, and I'm gonna be running a HIS Radeon HD 6850 and an AMD phenom x2 black edition 555 dual core that will unlock to 3-4 cores. What's the best way to determine how big of a power supply I need? Like I said I'm on a budget, and I'll downgrade the power supply wattage to downgrade the price :sol:
Is the amount of power needed by a power supply determined by the required wattage of the GFX card combined with the required wattage of the processor? Thanks
How about this for 700$ -
Asrock 870 Extreme3
www.newegg.com/Product/Product.aspx?Item=N82E16813157198
AMD Phenom II X4 955
www.newegg.com/Product/Product.aspx?Item=N82E16819103808
2 x 2GB DDR 1333 MHz RAM
www.newegg.com/Product/Product.aspx?Item=N82E16820231275
Radeon HD 6850 1GB Video Card
www.m.newegg.com/Product/Product.aspx?Item=N82E16814150516
Samsung SpinPoint F3 1TB Hard Drive
www.newegg.com/Product/Product.aspx?Item=N82E16822152185
Asus DVD Writer
www.newegg.com/Product/Product.aspx?Item=N82E16827135204
Antec 300 Illusion
www.newegg.com/Product/Product.aspx?Item=N82E16811129066
Antec 750W PSU
www.newegg.com/Product/Product.aspx?Item=N82E16817371025
Asrock 870 Extreme3
Asus DVD Writer
Antec 300 Illusion
Antec 750W PSU
jockey
746
49
I'd recommend getting a 600W PSU simply because of your plans to unlock the 555. It will automatically want more power, and I feel that playing it safe with a higher wattage PSU would be a benefit for you. Plus the upgrade factor down the road.
gamerx456
35
That benchmark testing really helped :)
Similar threads
