A broken water pump for a well looks something like this
but it's a different model It broke down last year in the fall that it buzzed a little louder than normal when it pumps water, I turned it on for over a minute or about 2 minutes and then I thought that the water must be taken from the well to the hose, it takes time but still does not want to pump. Did this pump just break down more that I turned it on for 2 minutes. Why won't this one pump water when it hums. Can this pump be repaired? Can this pump be repaired? How much is the cheapest new pump in the store? This pump was bought 3 years ago in a store, is it still under warranty? Can this pump be repaired? Is it possible to buy just a broken part for the pump? Is better buy used pumps or only new ones?
