How can fix hdds errors?
Nick_mati
24
My drives (in crystaldisk info AND hd tune pro) showing crc error 2 attention,CURRENT PENDING SECTOR ERROR COUNT 252 to 94,After ac power loss,seagate seatools showing short generic test fail for samsung hd ,AND WD diag showing smart pass for wd and samsung too,but failing in smart test(samsung hd)
For Crystal Disk Info click on Fuction at the top then Advanced and then Raw Values. Change that to 10 DEC first of all.
Second of all you want to get the number from the Raw Values section.
What is it saying for that number.
Is it an external or internal drive? Who is the manufacturer? Usually, the manufacturer will provide a diagnostic utility for their drives. Seagate will have Seatools for Windows or Seatools for DOS. WD will be data lifeguard if I am not mistaken. Most of the time, the manufacturer will prefer you use their software and may not support third party software.
Hi there Nick_mati,
This basically means that there are some bad sectors on your drive. They will eventually continue to appear and you can't stop this process. I would advise you to back up the important data that is stored on it as the drive is considered to be unreliable.
Follow drtweak advise and see what is the actual number of bad sectors in order to get a clearer picture of the condition of the drive.
I guess you can still use it, but just don't store crucial data on it.
Cheers,
D_Know_WD
CrystalDiskInfo 6.1.12 (C) 2008-2014 hiyohiyo
Crystal Dew World : http://crystalmark.info/
OS : Windows 7 Ultimate SP1 [6.1 Build 7601] (x86)
Date : 2015/03/05 20:38:13
-- Controller Map ----------------------------------------------------------
+ Intel(R) 7 Series/C216 Chipset Family SATA AHCI Controller [ATA]
- TSSTcorp CDDVDW SH-S223C SCSI CdRom Device
- WDC WD800JD-22JNC0 SCSI Disk Device
- SAMSUNG HD503HI SCSI Disk Device
- DAEMON Tools Virtual SCSI Bus [SCSI]
- Asmedia 106x SATA Controller [SCSI]
-- Disk List ---------------------------------------------------------------
(1) WDC WD800JD-22JNC0 : 80.0 GB [0/0/0, pd1] - wd
(2) SAMSUNG HD503HI : 500.1 GB [1/0/0, pd1]
Model : WDC WD800JD-22JNC0
Firmware : 05.01C05
Serial Number : WD-WCAM98298773
Disk Size : 80.0 GB (8.4/80.0/----/80.0)
Buffer Size : 8192 KB
Queue Depth : 1
# of Sectors : 156301488
Rotation Rate : Unknown
Interface : Serial ATA
Major Version : ATA/ATAPI-6
Minor Version : ----
Transfer Mode : ---- | SATA/150
Power On Hours : 10468 hours
Power On Count : 5996 count
Temperature : 37 C (98 F)
Health Status : Good
Features : S.M.A.R.T., AAM
APM Level : ----
AAM Level : 80FEh [OFF]
-- S.M.A.R.T. --------------------------------------------------------------
ID Cur Wor Thr RawValues(6) Attribute Name
01 200 200 _51 00000000002A Read Error Rate
03 192 159 _21 00000000055F Spin-Up Time
04 _94 _94 __0 0000000017B4 Start/Stop Count
05 200 200 140 000000000000 Reallocated Sectors Count
07 100 253 _51 000000000000 Seek Error Rate
09 _86 _86 __0 0000000028E4 Power-On Hours
0A 100 100 _51 000000000000 Spin Retry Count
0B 100 100 _51 000000000000 Recalibration Retries
0C _95 _95 __0 00000000176C Power Cycle Count
C2 106 _80 __0 000000000025 Temperature
C4 200 200 __0 000000000000 Reallocation Event Count
C5 200 200 __0 000000000000 Current Pending Sector Count
C6 200 200 __0 000000000000 Uncorrectable Sector Count
C7 200 200 __0 0000000008E2 UltraDMA CRC Error Count
C8 200 200 _51 000000000000 Write Error Rate
-- IDENTIFY_DEVICE ---------------------------------------------------------
0 1 2 3 4 5 6 7 8 9
000: 427A 3FFF C837 0010 0000 0000 003F 0000 0000 0000 Bz?..7.......?......
010: 2020 2020 2057 442D 5743 414D 3938 3239 3837 3733 WD-WCAM98298773
020: 0000 4000 0004 3035 2E30 3143 3035 5744 4320 5744 ..@...05.01C05WDC WD
030: 3830 304A 442D 3232 4A4E 4330 2020 2020 2020 2020 800JD-22JNC0
040: 2020 2020 2020 2020 2020 2020 2020 8010 0000 2F00 ..../.
050: 4001 0000 0000 0007 3FFF 0010 003F FC10 00FB 0110 @.......?....?......
060: F8B0 0950 0000 0007 0003 0078 0078 0078 0078 0000 ...P.......x.x.x.x..
070: 0000 0000 0000 0000 0000 0000 0202 0000 0000 0000 ....................
080: 007E 0000 3469 5B01 4003 3469 1801 4003 207F 0000 .~..4i[.@.4i..@. ...
090: 0000 0000 FFFE 0000 80FE 0000 0000 0000 0000 0000 ....................
100: 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 ....................
110: 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 ....................
120: 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 ....................
130: 0000 0000 0000 1653 0000 0000 0000 0000 0000 0000 .......S............
140: 0000 0000 0004 0000 0000 0000 0000 0000 0000 0000 ....................
150: 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 ....................
160: 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 ....................
170: 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 ....................
180: 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 ....................
190: 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 ....................
200: 0000 0000 0000 0000 0000 0000 003F 0000 0000 0000 .............?......
210: 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 ....................
220: 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 ....................
230: 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 ....................
240: 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 ....................
250: 0000 0000 0000 0000 0000 BFA5 ............
-- SMART_READ_DATA ---------------------------------------------------------
+0 +1 +2 +3 +4 +5 +6 +7 +8 +9 +A +B +C +D +E +F
000: 10 00 01 0F 00 C8 C8 2A 00 00 00 00 00 00 03 03 .......*........
010: 00 C0 9F 5F 05 00 00 00 00 00 04 32 00 5E 5E B4 ..._.......2.^^.
020: 17 00 00 00 00 00 05 33 00 C8 C8 00 00 00 00 00 .......3........
030: 00 00 07 0F 00 64 FD 00 00 00 00 00 00 00 09 32 .....d.........2
040: 00 56 56 E4 28 00 00 00 00 00 0A 13 00 64 64 00 .VV.(........dd.
050: 00 00 00 00 00 00 0B 12 00 64 64 00 00 00 00 00 .........dd.....
060: 00 00 0C 32 00 5F 5F 6C 17 00 00 00 00 00 C2 22 ...2.__l......."
070: 00 6A 50 25 00 00 00 00 00 00 C4 32 00 C8 C8 00 .jP%.......2....
080: 00 00 00 00 00 00 C5 12 00 C8 C8 00 00 00 00 00 ................
090: 00 00 C6 10 00 C8 C8 00 00 00 00 00 00 00 C7 3E ...............>
0A0: 00 C8 C8 E2 08 00 00 00 00 00 C8 09 00 C8 C8 00 ................
0B0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................
0C0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................
0D0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................
0E0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................
0F0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................
100: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................
110: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................
120: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................
130: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................
140: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................
150: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................
160: 00 00 00 00 00 00 00 00 00 00 82 00 9C 09 01 7B ...............{
170: 03 00 01 00 02 23 05 00 00 00 00 00 00 00 00 00 .....#..........
180: 00 00 01 02 00 00 00 00 00 00 00 00 00 00 00 00 ................
190: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................
1A0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................
1B0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................
1C0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................
1D0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................
1E0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................
1F0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 5B ...............[
-- SMART_READ_THRESHOLD ----------------------------------------------------
000: 10 00 01 33 C8 C8 00 00 00 00 00 00 00 00 03 15 ...3............
010: 00 00 00 00 00 00 00 00 00 00 04 00 00 00 00 00 ................
020: 00 00 00 00 00 00 05 8C 00 00 00 00 00 00 00 00 ................
030: 00 00 07 33 C8 C8 00 00 00 00 00 00 00 00 09 00 ...3............
040: 00 00 00 00 00 00 00 00 00 00 0A 33 00 00 00 00 ...........3....
050: 00 00 00 00 00 00 0B 33 00 00 00 00 00 00 00 00 .......3........
060: 00 00 0C 00 00 00 00 00 00 00 00 00 00 00 C2 00 ................
070: 00 00 00 00 00 00 00 00 00 00 C4 00 00 00 00 00 ................
080: 00 00 00 00 00 00 C5 00 00 00 00 00 00 00 00 00 ................
090: 00 00 C6 00 00 00 00 00 00 00 00 00 00 00 C7 00 ................
0A0: 00 00 00 00 00 00 00 00 00 00 C8 33 C8 C8 00 00 ...........3....
160: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................
170: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................
180: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................
1F0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 C2 ................
(2) SAMSUNG HD503HI
Model : SAMSUNG HD503HI
Firmware : 1AJ10001
Serial Number : S23CJ9CZA00386
Disk Size : 500.1 GB (8.4/137.4/500.1/500.1)
Buffer Size : 16384 KB
Queue Depth : 32
# of Sectors : 976773168
Rotation Rate : 5400 RPM
Major Version : ATA8-ACS
Minor Version : ATA8-ACS version 6
Transfer Mode : ---- | SATA/300
Power On Hours : 4381 hours
Power On Count : 2079 count
Temperature : 30 C (86 F)
Health Status : Caution
Features : S.M.A.R.T., APM, AAM, 48bit LBA, NCQ
APM Level : 0000h [OFF]
AAM Level : FE00h [OFF]
01 100 100 _51 0000000003C7 Read Error Rate
02 252 252 __0 000000000000 Throughput Performance
03 _85 _84 _25 00000000127D Spin-Up Time
04 _98 _98 __0 0000000008C9 Start/Stop Count
05 252 252 _10 000000000000 Reallocated Sectors Count
07 252 252 _51 000000000000 Seek Error Rate
08 252 252 _15 000000000000 Seek Time Performance
09 100 100 __0 00000000111D Power-On Hours
0A 252 252 _51 000000000000 Spin Retry Count
0B 100 100 __0 000000000001 Recalibration Retries
0C _98 _98 __0 00000000081F Power Cycle Count
BF 100 100 __0 000000000002 G-Sense Error Rate
C0 252 252 __0 000000000000 Power-off Retract Count
C2 _64 _50 __0 0032000F001E Temperature
C3 100 100 __0 000000000000 Hardware ECC recovered
C4 252 252 __0 000000000000 Reallocation Event Count
C5 _94 _94 __0 00000000010B Current Pending Sector Count
C6 252 252 __0 000000000000 Uncorrectable Sector Count
C7 100 100 __0 000000000002 UltraDMA CRC Error Count
C8 100 100 __0 00000000007E Write Error Rate
DF 100 100 __0 000000000001 Load/Unload Retry Count
E1 100 100 __0 00000000094B Load/Unload Cycle Count
0 1 2 3 4 5 6 7 8 9
000: 0040 3FFF C837 0010 0000 0000 003F 0000 0000 0000 .@?..7.......?......
010: 5332 3343 4A39 435A 4130 3033 3836 2020 2020 2020 S23CJ9CZA00386
020: 0000 8000 0050 3141 4A31 3030 3031 5341 4D53 554E .....P1AJ10001SAMSUN
030: 4720 4844 3530 3348 4920 2020 2020 2020 2020 2020 G HD503HI
040: 2020 2020 2020 2020 2020 2020 2020 8010 4000 2F00 ..@./.
050: 4000 0200 0200 0007 3FFF 0010 003F FC10 00FB 0110 @.......?....?......
060: FFFF 0FFF 0000 0007 0003 0078 0078 0078 0078 0000 ...........x.x.x.x..
070: 0000 0000 0000 0000 0000 001F 1706 0000 004C 0044 .................L.D
080: 01FF 0028 746B 7F69 4123 7469 BC41 4123 207F 0032 ...(tk.iA#ti.AA# ..2
090: 0032 0000 FFFE 0000 FE00 0000 0000 0000 0000 0000 .2..................
100: 6030 3A38 0000 0000 0000 0000 4000 0000 5002 4E92 `0:8........@...P.N.
110: 037C B114 0000 0000 0000 0000 0000 0000 0000 401C .|................@.
120: 401C 0000 0000 0000 0000 0000 0000 0000 0029 0000 @................)..
130: 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 ....................
140: 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 ....................
160: 0000 0000 0000 0000 0000 0000 0000 0000 0002 0000 ....................
210: 0000 0000 0000 0000 0000 0000 0000 1518 0000 0000 ....................
220: 0000 0000 101F 0000 0000 0000 0000 0000 0000 0000 ....................
230: 0000 0000 0000 0000 0001 0400 0000 0000 0000 0000 ....................
250: 0000 0000 0000 0000 0000 66A5 ..........f.
000: 10 00 01 2F 00 64 64 C7 03 00 00 00 00 00 02 26 .../.dd........&
010: 00 FC FC 00 00 00 00 00 00 00 03 23 00 55 54 7D ...........#.UT}
020: 12 00 00 00 00 00 04 32 00 62 62 C9 08 00 00 00 .......2.bb.....
030: 00 00 05 33 00 FC FC 00 00 00 00 00 00 00 07 2E ...3............
040: 00 FC FC 00 00 00 00 00 00 00 08 24 00 FC FC 00 ...........$....
050: 00 00 00 00 00 00 09 32 00 64 64 1D 11 00 00 00 .......2.dd.....
060: 00 00 0A 32 00 FC FC 00 00 00 00 00 00 00 0B 32 ...2...........2
070: 00 64 64 01 00 00 00 00 00 00 0C 32 00 62 62 1F .dd........2.bb.
080: 08 00 00 00 00 00 BF 22 00 64 64 02 00 00 00 00 .......".dd.....
090: 00 00 C0 22 00 FC FC 00 00 00 00 00 00 00 C2 02 ..."............
0A0: 00 40 32 1E 00 0F 00 32 00 00 C3 3A 00 64 64 00 .@2....2...:.dd.
0B0: 00 00 00 00 00 00 C4 32 00 FC FC 00 00 00 00 00 .......2........
0C0: 00 00 C5 32 00 5E 5E 0B 01 00 00 00 00 00 C6 30 ...2.^^........0
0D0: 00 FC FC 00 00 00 00 00 00 00 C7 36 00 64 64 02 ...........6.dd.
0E0: 00 00 00 00 00 00 C8 2A 00 64 64 7E 00 00 00 00 .......*.dd~....
0F0: 00 00 DF 32 00 64 64 01 00 00 00 00 00 00 E1 32 ...2.dd........2
100: 00 64 64 4B 09 00 00 00 00 00 00 00 00 00 00 00 .ddK............
160: 00 00 00 00 00 00 00 00 00 00 00 79 24 18 00 5B ...........y$..[
170: 03 00 01 00 02 67 00 00 00 00 00 00 00 00 00 00 .....g..........
1F0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 D1 ................
000: 10 00 01 33 00 00 00 00 00 00 00 00 00 00 02 00 ...3............
010: 00 00 00 00 00 00 00 00 00 00 03 19 00 00 00 00 ................
020: 00 00 00 00 00 00 04 00 00 00 00 00 00 00 00 00 ................
030: 00 00 05 0A 00 00 00 00 00 00 00 00 00 00 07 33 ...............3
040: 00 00 00 00 00 00 00 00 00 00 08 0F 00 00 00 00 ................
050: 00 00 00 00 00 00 09 00 00 00 00 00 00 00 00 00 ................
060: 00 00 0A 33 00 00 00 00 00 00 00 00 00 00 0B 00 ...3............
070: 00 00 00 00 00 00 00 00 00 00 0C 00 00 00 00 00 ................
080: 00 00 00 00 00 00 BF 00 00 00 00 00 00 00 00 00 ................
090: 00 00 C0 00 00 00 00 00 00 00 00 00 00 00 C2 00 ................
0A0: 00 00 00 00 00 00 00 00 00 00 C3 00 00 00 00 00 ................
0B0: 00 00 00 00 00 00 C4 00 00 00 00 00 00 00 00 00 ................
0C0: 00 00 C5 00 00 00 00 00 00 00 00 00 00 00 C6 00 ................
0D0: 00 00 00 00 00 00 00 00 00 00 C7 00 00 00 00 00 ................
0E0: 00 00 00 00 00 00 C8 00 00 00 00 00 00 00 00 00 ................
0F0: 00 00 DF 00 00 00 00 00 00 00 00 00 00 00 E1 00 ................
1F0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 3B ...............;
Both drives are Internal. Seatools and wd dlg showing error ..
HD Tune Pro: Samsung HD503HI S.M.A.R.T.
Status ID Current Worst Threshold Value Description
OK (01) Raw Read Error Rate 100 100 51 967 Number of hardware read errors: 967
OK (02) Throughput Performance 252 252 0 0
OK (03) Spin Up Time 85 84 25 4733 Spin up time: 4.7 seconds
OK (04) Start/Stop Count 98 98 0 2249 Number of start/stop cycles: 2249
OK (05) Reallocated Sector Count 252 252 10 0 Number of retired sectors : 0
OK (07) Seek Error Rate 252 252 51 0 Number of seek errors: 0
OK (08) Seek Time Performance 252 252 15 0 Seek time performance
OK (09) Power On Hours Count 100 100 0 4381 Number of hours in power-on state: 4381 (182 days)
OK (0A) Spin Retry Count 252 252 51 0 Number of spin up attempts after a spin up failure: 0
Attention (0B) Calibration Retry Count 100 100 0 1 Number of calibration attempts after a calibration failure: 1
OK (0C) Power Cycle Count 98 98 0 2079 Number of power on/off cycles: 2079
OK (BF) G-sense Error Rate 100 100 0 2
OK (C0) Unsafe Shutdown Count 252 252 0 0
OK (C2) Temperature 64 50 0 214749347870 Temperature: 30°C
OK (C3) Hardware ECC Recovered 100 100 0 0 Number of error code correction (ECC) errors: 0
OK (C4) Reallocated Event Count 252 252 0 0 Number of sector replacement operations: 0
Attention (C5) Current Pending Sector 94 94 0 267 Number of unstable sectors: 267
OK (C6) Offline Uncorrectable 252 252 0 0 Number of uncorrected errors: 0
Attention (C7) Interface CRC Error Count 100 100 0 2 Number of interface communication errors: 2
OK (C8) Write Error Rate 100 100 0 126 Number of write errors: 126
OK (DF) Load/Unload Retry Count 100 100 0 1
OK (E1) Load/Unload Cycle Count 100 100 0 2379
Attentions : 1
Warnings : 2
Failures : 0
HD Tune Pro: WDC WD800JD-22JNC0 S.M.A.R.T.
OK (01) Raw Read Error Rate 200 200 51 42 Number of hardware read errors: 42
OK (03) Spin Up Time 192 159 21 1375 Spin up time: 1.4 seconds
OK (04) Start/Stop Count 94 94 0 6068 Number of start/stop cycles: 6068
OK (05) Reallocated Sector Count 200 200 140 0 Number of retired sectors : 0
OK (07) Seek Error Rate 200 200 51 0 Number of seek errors: 0
OK (09) Power On Hours Count 86 86 0 10468 Number of hours in power-on state: 10468 (436 days)
OK (0A) Spin Retry Count 100 100 51 0 Number of spin up attempts after a spin up failure: 0
OK (0B) Calibration Retry Count 100 100 51 0 Number of calibration attempts after a calibration failure: 0
OK (0C) Power Cycle Count 95 95 0 5996 Number of power on/off cycles: 5996
OK (C2) Temperature 106 80 0 37 Temperature: 37°C
OK (C4) Reallocated Event Count 200 200 0 0 Number of sector replacement operations: 0
OK (C5) Current Pending Sector 200 200 0 0 Number of unstable sectors: 0
OK (C6) Offline Uncorrectable 200 200 0 0 Number of uncorrected errors: 0
Attention (C7) Interface CRC Error Count 200 200 0 2274 Number of interface communication errors: 2274
OK (C8) Write Error Rate 200 200 51 0 Number of write errors: 0
Attentions : 1
Warnings : 0
Failures : 0
i tried to replace sata cable ..samsung sata cable into wd ..now wd showing Attention (C7) Interface CRC Error Count 200 200 0 2274 Number of interface communication errors: 2274
According to the results, your Samsung HDD seems go have some bad sectors. You need to back up the data.
The WD drive seems to be fine. Though, this difference in the values after attaching the Samsung's cable to the drive, may indicate some SATA cable problem(Interface CRC Error Count). Just switch around cables and see whether the results will be different. You may need to get a new SATA cable.
Cheers,
D_Know_WD
yeah,i tried another sata cable,but its showing same error
yeah
i am thinking to buy wd ezex 1tb or toshiba
here wd black isn't available in retail store's,...
but wd blue and green available,also seagate brcda/sv 35.
yeah,i need a drive for games,movies,software and storage too..Is wdezex 1tb good ?
purchsd..wd100ezex 1tb showing 951gb in bios,and 931.5gb in win 7 32bit. i checked in crystal disk info showing reallocated sector count 140 thrshld. is it ok or ? ,
and its still not showing in windows
HD Tune: WDC WD10EZEX-00BN5A0 Health
ID Current Worst ThresholdData Status
(01) Raw Read Error Rate 200 200 51 0 Ok
(03) Spin Up Time 100 253 21 0 Ok
(04) Start/Stop Count 100 100 0 3 Ok
(05) Reallocated Sector Count 200 200 140 0 Ok
(07) Seek Error Rate 100 253 0 0 Ok
(09) Power On Hours Count 100 100 0 0 Ok
(0A) Spin Retry Count 100 253 0 0 Ok
(0B) Calibration Retry Count 100 253 0 0 Ok
(0C) Power Cycle Count 100 100 0 3 Ok
(C0) Power Off Retract Count 200 200 0 1 Ok
(C1) Load Cycle Count 200 200 0 1 Ok
(C2) Temperature 106 106 0 37 Ok
(C4) Reallocated Event Count 200 200 0 0 Ok
(C5) Current Pending Sector 200 200 0 0 Ok
(C6) Offline Uncorrectable 100 253 0 0 Ok
(C7) Ultra DMA CRC Error Count 200 200 0 0 Ok
(C8) Write Error Rate 100 253 0 0 Ok
Power On Time : 0
Health Status : Ok
