Z zunigast1 Jan 4, 2019 1 0 10 Jan 4, 2019 #1 It didn't come with one but has the space plate. Can i install a CD/DVD writer
Barty1884 Retired Moderator Apr 16, 2015 22,254 1,355 108,740 Jan 4, 2019 #2 Assuming there's physically space inside, you should just be able to remove the plate (likely after removing the underside cover) and slide an optical drive in. Upvote 0 Downvote
R robert600 Distinguished Jan 19, 2012 1,279 45 19,840 Jan 5, 2019 #3 You have to be a bit careful when ordering ... the C series doesn't use the same one as the A and B series. Portable dvd burners work great and are probably cheaper. Upvote 0 Downvote
