J jmehrhardt1 Apr 22, 2018 1 0 10 Apr 22, 2018 #1 How to add a subwoofer to a 2 channel receiver without any other output?
Solution A A americanaudiophile Apr 23, 2018 Connect a speaker to line level converter in parallel with the speakers. Connect the subwoofer to it.
A Alabalcho Titan Jan 13, 2011 14,016 433 81,090 Apr 22, 2018 #2 By using an audio-splitter, possibly a separate subwoofer amp or possible cut-down filter if your subwoofer does not have one. Upvote 0 Downvote
A americanaudiophile Titan Aug 27, 2008 13,663 0 101,360 Apr 23, 2018 Solution #3 Connect a speaker to line level converter in parallel with the speakers. Connect the subwoofer to it. Upvote 0 Downvote Solution
