I have 2X512 GeIL Dual(CL25-4-4DDR400) PC3200(200MHz)..and they are working at 133.8 MHz. with SPD timing at 3-4-4-15-4
When I try other SPD combination like 2-3-3-5 etc its entering windows but after 2 min or when I'trying other aplication its having restart..over and over until I'm entering bios,adjusting once again the timings to default.
My MB(Asus P5GD1) its have a AI overcloking with an option to grow the voltage of the RAM and the Frequency..I did some changes selecting much higher voltage but still the same problem.
Advance Chipset Settings looks like this
Config DRAM Timing by SPD [disable] (in this mode i can adjust the timing)
DRAM CAS# Latency(tCL) 3 [2.0;2,5;3]
DRAM RAS# Precharge(tRP) 4 [2;3;5]
DRAM RAS# to CAS# Delay(tRCD) 4 [2;4;5]
DRAM RAS# Activate to Precharge(tRAP) 15 [1;2;3....;15]
DRAM Write Recovery timing(tWR) 4 [2;3;5]
This ist the default timing
I try different combination in most of them windows its restarting after few min. and none of them didn't reach the 200MHz."Cpuz" its telling me the right frequency and the combination for 200MHz but its still not working.
How can I raise the frequency and adjust the timing in the way its compatible with the system and having better performance.
I want the RAM to work at 200MHz but I don't find the right timing or the system its not compatible.
With "rmma" like"Cpuz" its give me the option to adjust the timing from there not from BIOS(it is safe to use this option?).
Sorry for my bad english. With respect Gorjan Dragos
