M majorlazer686 Mar 30, 2018 5 0 10 Mar 30, 2018 #1 I have to change my output HDMI port into input port. Is there any software for it , PC . AIO has only one HDMI port....plz help me..
Solution USAFRet Mar 30, 2018 majorlazer686 : I have to change my output HDMI port into input port. Is there any software for it , PC . AIO has only one HDMI port....plz help me.. You can't. There is no magic dust you can sprinkle on it to change that.
webworkings Titan Apr 6, 2016 11,201 0 86,610 Mar 30, 2018 #2 You can't. And software can't change that. What are you trying to do exactly that makes you want to change the output to input? Upvote 0 Downvote
USAFRet Titan Moderator Mar 16, 2013 179,624 22,150 184,590 Mar 30, 2018 Solution #3 majorlazer686 : I have to change my output HDMI port into input port. Is there any software for it , PC . AIO has only one HDMI port....plz help me.. You can't. There is no magic dust you can sprinkle on it to change that. Upvote 0 Downvote Solution
M majorlazer686 Mar 30, 2018 5 0 10 Mar 30, 2018 #4 webworkings : You can't. And software can't change that. What are you trying to do exactly that makes you want to change the output to input? Upvote 0 Downvote
USAFRet Titan Moderator Mar 16, 2013 179,624 22,150 184,590 Mar 30, 2018 #6 majorlazer686 : I have to connect my TV to PC You're looking to display the PC contents on the TV? So....OUT from the PC...IN to the TV. As it is currently. Upvote 0 Downvote
M majorlazer686 Mar 30, 2018 5 0 10 Mar 30, 2018 #7 USAFRet : majorlazer686 : I have to connect my TV to PC You're looking to display the PC contents on the TV? So....OUT from the PC...IN to the TV. As it is currently. Upvote 0 Downvote
M majorlazer686 Mar 30, 2018 5 0 10 Mar 30, 2018 #8 No I have to see settop box to PC . my PC is AIO Upvote 0 Downvote
USAFRet Titan Moderator Mar 16, 2013 179,624 22,150 184,590 Mar 30, 2018 #9 majorlazer686 : No I have to see settop box to PC . my PC is AIO This, you cannot do. Upvote 0 Downvote
