M Mr.No1 Feb 24, 2019 5 0 10 Feb 26, 2019 #1 How to check the gray wire using a multimatter device The gray wire and? Wire ...? help!
Solution kanewolf Feb 26, 2019 This page -- https://en.wikipedia.org/wiki/ATX#Power_supply says that the grey wire is the power good signal. I would think +5VDC when the other voltages are correct. For $8, this is a much easier method -- https://www.newegg.com/Product/Product.aspx?Item=9SIA4RE84S1129
kanewolf Titan Moderator May 29, 2013 37,314 3,275 156,790 Feb 26, 2019 Solution #2 This page -- https://en.wikipedia.org/wiki/ATX#Power_supply says that the grey wire is the power good signal. I would think +5VDC when the other voltages are correct. For $8, this is a much easier method -- https://www.newegg.com/Product/Product.aspx?Item=9SIA4RE84S1129 Upvote 0 Downvote Solution
