T Teo Tea Reputable Feb 25, 2015 1 0 4,510 Feb 25, 2015 #1 My monitor has a DL DVI-D port but my PC has a DL DVI-I port... Is it possible to make it work? What kind of cable should I buy?
Solution AdviserKulikov Feb 25, 2015 Your monitor should have come with a DVI-D cable, DVI-I output will support both DVI-D and DVI-A devices. If you do not have an appropriate cable, you need a DVI-D cable.
AdviserKulikov Honorable Jan 13, 2015 1,099 0 11,960 Feb 25, 2015 Solution #2 Your monitor should have come with a DVI-D cable, DVI-I output will support both DVI-D and DVI-A devices. If you do not have an appropriate cable, you need a DVI-D cable. Upvote 1 Downvote Solution
