Question How can I connect 6 pin fans to motherboard?
alitiz
4
I've bought some chinese coolmoon fans and they came with a fan hub that connects to psu and you control them with an rgb remote.
My problem is that they're really loud at full speed, and everytime I turn on the pc I have to manually lower the speed with the remote. Since the hub is connected to psu I know that's the normal behaviour, but it's the fans that sound bad.
Is there any way to connect them to the motherboard? (And by that i mean even mod them from 6pin to 4pin, or get an adapter or a new 6pin fan hub with mobo connectivity)
Thanks for any answer
Mod Edit - Language
Are these the fans that you're working with? If so, then nope, there's no way you're going to get around to controlling them off the motherboard, unless you want to fry the motherboard as well. The issue being that the connectors are proprietary. You should ditch the fans and pick up some that have both PWM and ARGB/RGB connectivity standalone for manipulating/management.
Yeah they're almost the same, same hub, almost same design.
After a lot of research i finally found this Coolmoon custom controller .I think it's only to control the rgb though
