F Fer DLC Commendable Apr 29, 2017 78 1 1,630 Jul 6, 2017 #1 My mother board only has 3 chassis fan connectors and i wanna connect a fourth case fan, how can i do this if my motherboard doesn't have an extra connector?
Solution The Paladin Jul 6, 2017 you can use a fan splitter for that header, meaning those 2 fans will be controlled by one header ; header splitter : https://www.newegg.com/Product/Product.aspx?Item=N82E16812162026&cm_re=fan_wire_splitter-_-12-162-026-_-Product
The Paladin Titan Ambassador Oct 5, 2016 9,659 62 75,340 Jul 6, 2017 Solution #2 you can use a fan splitter for that header, meaning those 2 fans will be controlled by one header ; header splitter : https://www.newegg.com/Product/Product.aspx?Item=N82E16812162026&cm_re=fan_wire_splitter-_-12-162-026-_-Product Upvote 0 Downvote Solution
raisonjohn Expert Ambassador Feb 22, 2015 4,102 102 39,040 Jul 6, 2017 #3 Use a fan splitter: https://www.amazon.com/SilverStone-Technology-Sleeved-Splitter-CPF01/dp/B00B46XKKQ Upvote 0 Downvote
