Hello, everyone!
The (very cheap) PSU that came with the case of my new emergency/tight budget build doesn’t seem to have a connector that fits my GPU: View: https://imgur.com/a/Ua3JQ1w
It has: a 20+4 pin connector (motherboard), a 4+4 pin connector (4 pins fit into the CPU_PWR1 socket on the motherboard), 2 x SATA, 2 X Molex, 1 x Floppy(?!) connectors.
The 4+4 pin connector doesn’t fit into the GPU socket. The GPU also came with a connector in its box. It has 8 pins on one side and 2 X 6 pins on the other side. I can plug the 8 pin part into the GPU, but how could I connect the 6 pin part to the PSU? There is no socket or cable for it.
So, I wonder:
Can anyone help? If you need any more details or photos, please let me know and I’ll get back to you as quickly as possible. Thanks!
So, I wonder:
- Does the GPU have to be connected to the PSU or does it get enough power through the motherboard?
- If it needs a PSU connection, what connector could I plug into the GPU socket?
- I feel like this is a stupid question, but I’m going to ask anyway: could I possibly connect the other part of the PSU 4+4 pin to the GPU or to the 8 pin to 2x6 pin adapter? Or would I risk something frying or not getting enough power?
- motherboard: MSI B450M-A PRO MAX (micro-ATX)
- CPU: AMD Ryzen 3 3100 3.6 GHz Quad-Core Processor (3rd gen) + Wraith Stealth cooler (which I kept, hoping that it would be doing its job for a little while)
- GPU: XFX Radeon RX 570 RS 8GB GDDR5 256-bit
- RAM: Corsair Vengeance LPX Black 16GB DDR4 3000MHz CL16 Dual Channel Kit
- SSD: Kingston A2000 500GB PCI Express 3.0 x4 M.2 2280
- HDD: Western Digital Blue 1 TB 3.5" 7200RPM (from my old PC)
- monitor: Dell SE2717H 27.0" 1920x1080 75Hz (from my old PC)
- PSU: Segotep ATX-500W (came with the case, nonmodular; GPU manufacturer recommends 550W, but lists 500W as the minimum requirement)
- case: Segotep S3 Black
- optical drive: an older LG DVD-RW which I intend to keep
