How can i connect to my parents wifi router 4.5km away from where i stay...
Odinslaw
How can i connect to my parents wifi router 4.5km away from where i stay can i build yagi's and how can i get a router box at my home to plug in voip phones??? any advice?
you would have to wire a 4.5km cable that will actually keep the data for that distance. You will have to have repeaters that take the signal and give it more strength along the way. This will cost millions of dollars but it is worth it to get internet from your parents.
The problem is there are no ADSL Lines where i stay it is on a small farm closest to me are my parents and the only point available for ADSL Lines, so it is open line of site i will manage to build a yagi transmitting the wifi signal from point A to point B.. this is not impossible as i see wifi networks that are near them all i need to know is how to get that signal into a router so i can plug in VoIP phones via LAN cable.
I actually looked at this a little while ago, there are a few things you need to have:
1) rough line of sight.
2) Ubiquiti Nanostation 5.
Depending on your distance and obstructions in the way, you may or may not have stellar results. I was actually looking to use this to connect my work to my home.
