Hi all,
I'm searching for software which can be used to (quickly) change your CPU/fan speed.
I regularly use my laptop for gaming, causing it to become really hot, mostly around temps of 90-100C. I don't think these are desirably temps..
I know AMD cpu's are known to run on hight temps but this is just too hot for me, I don't want to get my hands and cpu burned while gaming.. 🙁
I'm using my HP Pavilion 17 e072nr laptop for about 3 months now so dust couldn't be really the problem. The things I've already done:
-I've already set the 'Fan always on' option enabled in BIOS, but I want it to always run on full speed, noise doesn't matter. Other options like fan-voltage control are not available in my BIOS.
-Speedfan doesn't recognize my fans so this option doesn't apply.
-I've set up optimal power plans in control panel, 100%cpu and cooling for 'Performance' and 60%cpu and 100%cooling for 'Recommended' scheme. I'm switching to recommended when I stop gaming but this only causes te cpu to drop a few degrees, like to 82C.
My specs are:
2.1Ghz quad AMD A8 accelerated to 3Ghz max. w/ 8GB ram.
Graphics card etc. is running just right around 45-50C
Many thanks in advance for any help, let me know if you need more info/specs
My specs are:
