Question How can I find a case that will work with an HP motherboard (micro ATX) from a pre built PC?
Nov 7, 2024
7
I bought a pre built HP gaming PC, and it's been great for me. It's very small, and has a mini ATX motherboard. I want to upgrade from my current PSU and GPU, but I need a new case to fit them and my current motherboard.
The only issue is that I'm worried the motherboard won't be aligned in the case properly since seemingly it's from a case designed for the motherboard. Does anyone know what I should do? Also, every case I find has its own front ports, but the motherboard has its own, too.
Those boards are designed to work only with the case it is installed into at the factory. Good luck finding anything that will properly connect up with it. In addition it is quite common for the board to be custom manufactured with a non standard hole pattern that will not fit a generic case at all.
Nov 7, 2024
7
Thank you
Nov 7, 2024
7
What if I get a new motherboard and just use what's on my current one?
