How can i fix my monitor screen
tm8822
4
My monitor is only showing up like a movie where the top and bottom are black and I cant even put my mouse in those portions
Sounds like the resolution is set incorrectly.
Right click on desktop
Select "screen resolution"
Choose the screen resolution drop down box and select the monitors native resolution. Will probably be labeled as (recommended).
And if you don't know what is the native resolution of your monitor, most of the time it's the last one (or highest one) on the list.
Correct me if I'm wrong, but usually with Windows when you don't use the native resolution you'll get a pop-up warning shortly after you log in. Some monitors also display a warning when outside the recommended resolution. But I think you get these warnings with DVI only, I don't think it works when connected with a VGA cable.
