G grrsona Honorable Feb 13, 2014 339 0 10,780 Oct 27, 2016 #1 I have a monitor with a headphone jack, but it also has 144hz, so I use DVI, how can I activate the audio jack without using hdmi?
Solution M M muddyparrot Oct 27, 2016 Short answer is you cant, dvi does not transmit sound, can you not plug the headphones directly into your pc?
M muddyparrot Distinguished Jun 24, 2013 265 0 18,960 Oct 27, 2016 Solution #2 Short answer is you cant, dvi does not transmit sound, can you not plug the headphones directly into your pc? Upvote 0 Downvote Solution
Wolfshadw Titan Moderator Aug 3, 2006 28,491 1,676 133,290 Oct 29, 2016 #3 Depends on your graphics card. There may be a two pin audio connection port on the card that you would plug into from an audio port on your motherboard. -Wolf sends Upvote 0 Downvote
