How can I hook up my Panasonic TV 2011 series to my Kenwood receiver
I have a Panasonic 47 inch plasma I'm trying to hook up my surround sound but my receiver which is a Kenwood do not have a HDMI it only has the RCA jacks and the optical what can I do
If you have an optical out or an analog out on the TV you don't need a converter
If you don't, you need a converter.
The type of converter depends on what type of audio outputs you have on the TV.
Although here's something you can probably do. Come out of the headphone jack with a 1/8" stereo to RCA adapted cable and then to the receiver.
This will work but may disable your TV speakers.
