How can I improve air flow in my matx form case?
Apr 19, 2018
Hello I am hoping that someone can help me figure out an airflow issue with my HP Envy 750-055xt. Being a matx/uatx case, I believe that my 4790k and GTX 970 has not been getting adequate air flow. I am upgrading my PSU from which was the maximum offered by the manufacturer to a fully modular 80+ gold 650W psu that comes with a slightly larger 135mm exhaust fan. The case came with a 120mm exhaust fan, no side or front fan, and a decent sized side vent on the case but unfortunately did not come with a side fan. I have some space in my 3.5" bays facing to the side panel, but I don't want to risk installing and intake that will pull air in from the CPU fan or the GPU. HP claims that my heatsink assembly is approximately 4x4x2.75", so I think the fan is 80mm but I could not find the dimensions online. The video card fans face upwards, and I believe that the fans push air towards the GPU. The processor's heatsink assembly is located below the GPU and blows air away from the processor, and the case exhaust fan is also located below the GPU mounted to the rear of the chassis. The side panel vents fill up approximately 1/3 of the side panel of my case, leaning more toward the the front of the tower.
I am considering changing the stock 120mm exhaust fan and the 80mm cpu fan, however I am not sure if my problems will be fixed since there may not be adequate intake. I'm trying to avoid a situation where after I install an intake then hot air may be pulled toward the intake and away from the rear exhaust. My ambient temp is 22 degrees C, GPU and CPU core temps hit above 80 C at load at 90-95% cpu use. Some heat issues may be due to the inefficient bronze rated 500W PSU. I have not even OC'd my processor- it is currently running at its standard 4.0ghz state. My goal is to lower my temps with hopes that i can OC but I don't want to risk adding heat to an already hot situation. I would rather not buy a new case and move everything over if I can avoid doing it. Can anyone help me figure out an airflow-fix solution (with low noise hopefully) to this problem?
Edit-- The motherboard is a Kaili2 z97 motherboard, picture can be found here https://support.hp.com/us-en/document/c04525350
One problem I see with getting a larger cpu fan is that the 4 slots of ram which I use would be affected by the larger size of a heatsink assembly fan. I thought this might be helpful for anyone who reads this..
Edit 2- The current heatsink fan looks like this https://www.amazon.com/PartsCollection%C2%AE-HP-644724-001-CPU-Heatsink/dp/B0145YM0FO
I would not change the case. Normally the mobo that uses HP have front connectors non-standard and could have compatibility problems.
I think you can't OC, the mobo that uses HP are usually limited.
If you have not done so yet, replace the thermal grease from the CPU cooler. clean possible dirt from the cpu cooler.
Look to collect the cables as much as possible so they do not impede the air flow.
Thank you for your input Tony.
I can buy a case but I hear that the functional HP drivers may not work well with a new case for the card reader and optical drives are set up in a particular fashion. My dvd drive is set up vertically, the wifi receptors are towards the top, and my PSU is installed above the motherboard, and the gtx 970 GPU is positioned right below the psu. I am not sure if changing cases would be the best option because the dvdR/W is installed vertically into the case and the other attachments. Do you still agree that I should change cases?
Another option I have begun to pursue is to add 2 92mm case fans to the side panel to help with air intake, install a stronger 95mm cpu heat sink and fan (noctua), and install a stronger 92mm exhaust fan below the power supply and gpu. In total those cooling options cost me more than a new case would cost (~$120) but I assume buying a good case would run me about $100 for the case plus $100-150 for new fans and Heat Sink. I'm generally unable to overclock my 4790k right now due to the limitations caused by my HP bios, as it is crashing when I increase any turbo max powers or processor limit, so perhaps a cpu overclock may not be possible with my set up. However, I do want to help get my temps down as my GPU is needing 75% fan to stay under 80 degrees.
Please advise :]
