How can I locate a phone through GPS using a laptop ?
The legality is very questionable. A mobile provider might be able to track a sim card but not the phone itself and if the phone is stolen the first thing they would have done is get the old sim out
I see, but I saw there are some services for online tracking for all companies. As like you can track them just by asking a phone operator and the weird thing is that this is completely legal.
Hy! It depends on what is your mobile! If you have a windows phone you have to sign in that account which one you set on your phone. If you sign in with the correct e-mail adress, it will show you your phone(s). For example: I sign in, and I see it: Puposbali phone(s): Lumia 730. And next to it i can choose an option what am I want! I can ring/locate/lock/format the phone, and I can send a text on the screen. And it's work properly! It works, when your phone is off! And you have to do the same the other 2 platforms!
