How can I lower temps?
bobbypie67890
132
I7 5820k@4.5ghz
2x G1 Gaming 980 Ti's +100 mhz core +125mem +12v
Asus x99 Sabertooth
16gb 2400mhz Ram
850 Evo 250gb ssd
3tb Toshiba 7200 HDD
Corsair Rm1000I
H100i Gtx
I was just able to get my graphics card up to 91 degrees by using firestrike ultra and customizing it even more demanding than the stock settings.
I have 3 intakes and 3 exhausts.
I have ~1 inch between my cards but i might be able to move down another slot.
And you've independently verified the gpu temps? For most OC, you'll not need to raise the voltage to remain stable, and the G1's already have a decent OC, raising the gpu voltage on those cards will show very little gain.
Some of your issue maybe fan related. Most case fans are very broad radiating, but the 780t is a huge case, and you have a major heat source where there is no airflow, namely the mid left section above the psu, right where the gpus are. Try switching up a couple of fans, slap the case fan temporarily on the rad, and stick the rad fan down on bottom intake. Rad fans generally have higher SP, meaning the air will actually make it to the back of the case. Worst case scenario, stick a fan on stilts and stick it to the top of the psu (low rpm, 400-500, you want to move the air away from the gpus, not overpower the gpu fans)
My 970 at 99% usage on MGS:TPP at ultra settings and 2k resolution with fans at 67%, 23°C ambient in a define R5 (in a cubby, not open air) only sees 62°C. 90 is way too high. If stock voltage and good airflow won't drop valid temps, you'll need to look into a full custom loop, which should be viable in your case since it has 2x triple rad possibility.
I have quite literally done every type of temp testing, game teseting, benchmark testing, and fps testing you will commonly find on the internet. I have two problems my temps are too hot my computer isnt performing right even when the gpus are in the 65-80 zone
