How can I minimize frame drop while recording BF4 with Dxtory?
skilltroll
19
I recently bought a new r9 280x, expecting to record bf4 smoothly. The game runs at 75-80 fps, but dxtory drops around 20-30 frames while recording. Dxtory is recording 720p @ 30fps using the loss-less codec.
My specs:
i5 3570
r9 280x
1 TB Hard Drive *installed both bf4 and saving recording to*
128 GB SSD for boot
Also, any suggestions for another game recording software?
Thanks.
bro there are a lot of recording programs my favorit is bandicam easy for video less performance and records to 1080p just look for it by the way it can use video encoding from your gpu for better rec just go for the main site and see for your self check this
http://www.bandicam.com/product/how-to-record-battlefield-gameplay/
this is for video encoding
http://www.bandicam.com/support/tips/amd-app/
I hope it helps you a lot
