Don't fix the symptom, fix the problem. The fan ramping up is a result of heat, if you could lower the fan speed you may end up doing damage.
What temps are you getting?
How long have you had the laptop? Have you cleaned it out at all (physically and software)? Where do you use it? i.e on a desk, tray, bed... etc
