I want to provide music for a praise and worship gathering, using my Dell E1720 laptop as a source. I think it is integrated motherboard audio (SigmaTel Audio Codec), but it does have a 3.5mm stereo mini jack.
I want to power a pair of Alesis M1A's, which have just dropped 66%, because they are on closeout.
http://www.amazon.com/exec/obidos/tg/detail/-/B000EJTXZU/ref=ord_cart_shr?_encoding=UTF8&m=ATVPDKIKX0DER&v=glance
If I just up-adapter the 3.5mm jack to 1/4" Tip-Ring-Sleeve, and try to drive the M1A's with my sound card, am I going to get good results? Or do I need to put it through some form of a pre-amp first? I have an old Behringer Eurorack MX602A mixer that should do the job. Nothing fancy, but it should work.
http://www.behringer.com/EN/Products/MX602A.aspx
I had been looking at a set of Logitech Z520 speakers for my presentation, which I liked because they have a protective metal grill, which is helpful for travel. http://www.amazon.com/Logitech-Speaker-System-Z520-Black/dp/B002FU5QMA/ref=sr_1_1?ie=UTF8&s=electronics&qid=1258257591&sr=8-1
Then I saw the M1A's. I know the M1A's, and love them, and while I have not heard the Z520's, I imagine there is going to be no comparison as far as clarity of audio is concerned. I just need to know if either my laptop alone, or my laptop-mixer combination is going to be enough to drive the system.
Also, does anyone know how the JBL Control 2P's are going to compare to the Alesis M1A's? They also have a metal grill, but are not on closeout. Thanks.
