how can i reset dvd playerto factory settings without remote
how can i reset dvd player to factory settings without remote control. I can hear the dvd but strange picture flashing across screen
No I changed something in settings and it never worked since. it is a nordmende Nm80hddr. The remote I have is not the correct remote for it so it does very little. Just plugged dvd into another tv same result. No Manual. Thanks
Contact the maker for a copy of the manual if you need to or just contact their support and ask how to reset it. There may not be a way to reset it without going through the remote or the onscreen menus.
You don't see any push pin holes or anything similar on the thing?
