Question How can I run aura sync and Icue without issue
jessicat1261
Commendable
Jan 14, 2021
62
Quick question as I'm a bit confused... So I use aura sync to control my rgb light strip, they will freeze for some reason until I open aura sync. I also use Icue, as almost all of my components are corsair branded. It says I shouldn't run them together, so how do I work my way around that as when I close aura sync it'll stop the lights.I used to run them together, but had to stop after having an issue where my usb ports would cancel out after running a game and I think that's what caused it as it seemed to be fine when I uninstalled Asus aura.
try Armoury Crate & Aura Creator together vs the old Aura software.
and\or try a Corsair RGB hub and run all of your connected devices through it.
I have a commander pro which has my fans connected via an rgb hub plugged into one USB header in it, and the other is my AIO cooler. Also my fans are connected to it. What do you mean by the old software, sorry? I have this downloaded version with just Asus armoury https://www.asus.com/campaign/aura/us/download.php
