I am building a computer and need a cpu cooler. I am getting the Asus B85M-G as a motherboard, could you recommend a CPU cooler. And also is there a default measurement that goes with Cooler? thanks,
There are two things to be concerned about with coolers, height and RAM clearance. Height is dependent on the case rather than the motherboard. RAM clearance is partially about the cooler and partially about the RAM choice.
You want to look at the socket and see what type it is on the motherboard then find a CPU cooler that fits that specific socket, for example AM3, find a CPU cooler for AM3 processors. For more information and a guide to further assist you more in depth CPu Cooler guide
