G Germel Honorable Jun 26, 2012 1 0 10,510 Jun 26, 2012 #1 I have an Acer H274HL bmid monitor. Stores all claim it's an LED Box shows LCD. Can you telll me whoich it is?
MauveCloud Splendid May 7, 2010 2,829 0 21,960 Jun 26, 2012 #2 An LED monitor isn't a separate type of monitor from LCD. It's a subtype of LCD that uses an LED backlight (instead of fluorescent). Upvote 0 Downvote
ricardois Distinguished Dec 21, 2011 1,470 0 19,660 Jun 26, 2012 #3 Like @ MauveCloud said, all monitors have an LCD panel, but some have LED backlighting so it does have an LCD panel, what you must check is if the backlight is LED of CFL,etc... this one in specific : http://www.amazon.com/Acer-H274HL-BMID-27-Inch-Widescreen/dp/B0052DHFX0 the one you bought i think: IT does have LED background so yes it is categorized as LED. Upvote 0 Downvote
Dark Lord of Tech Retired Moderator Aug 18, 2009 128,643 1,789 159,590 Jun 26, 2012 #4 Acer H274HL BMID 27-Inch LED Widescreen LCD Display Upvote 0 Downvote
Pramit Kumar Biswas Reputable Aug 25, 2015 206 0 4,690 Sep 16, 2015 #5 Is also have a Dell E2015HV monitor. All claims its an LED. BUT on the back side of monitor its written LCD. Upvote 0 Downvote
hang-the-9 Titan Mar 25, 2010 60,377 1,081 152,940 Sep 18, 2015 #6 Pramit Kumar Biswas : Is also have a Dell E2015HV monitor. All claims its an LED. BUT on the back side of monitor its written LCD. Did you read the post fully? Read the first reply. Upvote 0 Downvote
