How can I tell if my motherboard is really overheating??? Plz help.
markusaurileus
215
Hi, according to a handful of hw monitoring programs I just installed, my ASUS P8Z68-V LE motherboard is overheating. I just bought this mobo and its really worrying me. What should I be looking for to see if it's a faulty sensor or if it's really overheating???
Like what spot on the motherboard should I feel to see if it's heating up?
Here are the programs and their readings:
AI Suite II: 22°C (hardly/doesn't fluxuate)
CPUID Hardware Monitor: SYSTIN ~21°C-23°C | CPUTIN ~67-127°C (up & down constantly) | AUXTIN ~68-71°C
Hmonitor: Mainboard 22°C | CPU2* 70°C
Speccy: 29-34°C (used to be ~80°C-125°C... until I ran Crysis 2)
SpeedFan: CPU* ~69-89°C | AUX 68-71°C
What's going on? Confusing me.
From the pic you posted and the readings for my HWMonitor and your Mobo's Layout
CPU temp is common and can be removed from the equation, so is the Mobo temp, since I have a 3.5"Temp Monitor with Sensors attached separately to every thing on the mobo I can usually tell which one is where when matching it with a Temp Monitoring Software.
The Mobo Temp is also something that is common and can be removed from the equation, that leaves us only with the Aux which on my external monitor shows me 45C and yours shows 70C. Mines placed on the HS next to the PCI Slots on my Mobo..... :)
It's pretty simple actually. Most mobos have sensor placements in a standard form....
The sensor on the mobo is wrong on many occasions, ...
Can u post a screenshot of the HW monitor?
Are the HDD's hot?
Or the CPU/GPU?
Don't stress yourself over that MarkusAurileus, it is not exact reading most of the time.
I would trust AI suite2, but if the sensor is not good, it will show wrong temps ...
There are about 3 to 4 places to actually check the temperature physically from.
The HSF, the base that's of metal can be felt with the finger tip while the rig is on .
The North Bridge and South Bridge, that would be the Heat sink just below the CPU and the SB would be the Heat Sink covering a patch on the Right Hand Side of the PCI Slots.
Then the heat sinks above the Mosfets at the left of the CPU and the top of it.
If I were you, I wouldn't use too many programs to check the temps. Stick to one reliable one that matches the temps that show up in the BIOS. And get rid of Speedfan...... that's a bad utility known to mess up a lot of rigs.
markusaurileus
215
All other temps are just as expected, only one of them are unsually high. I don't use multiple monitors, only SpeedFan, but when I saw the temp reading, I had to try out multiple ones, and they were all giving me sketchy readings of one particular high temp.
alyoshka, I did touch a few of the spots mentioned (heatsinks on the mobo and the mosfets), and they were not hot. I didn't know speedfan was bad : / will uninstall it now.
btw, I did a restart and Speccy showed a high mobo temp but lowered to normal after playing Crysis 2.
[edit: i'm not so sure AI Suite II is reliable since it's reporting cpu temp as 6°C]
HW Monitor is showing you the right temps. It so seems the Z68 Chip is the hottest.
Does your case have a side panel fan mounted? or a front panel intake fan mounted in it?
If not, a spot fan for the Z68 chip would help getting the temps down quite a bit.
markusaurileus
215
There's a 120mm intake fan in the lower front, and two 120 mm exhaust fans in the upper back. No side panel fans, though.
How'd you figure it's the z68 chipset that's getting hot?
Thx for the quick replies guys, btw
markusaurileus
215
Ahh ok. Thats pretty interesting actually. So since my temps spike up higher than normal, I'm guessing that's not ideal. I have a little less than 15 days to exchange the board. Should I go ahead and do that?
Actually you can do that, but ideally, a good airflow case brings that temp down considerably. You can exchange it and see if there is a difference, but if that does the same thing, then it means you will need to get a better case or atleast use a side panel fan to blow air onto that HS.
I don't believe these sensors and I think your mobo is fine, just sensor issue. Try to touch it and u will see its not all that hot.
U can get temp gun to see the real temps : )
Look at mine screen ...
markusaurileus
215
Ok. Thanks guys. I'll try exchanging it first. If the temp is about the same, imma install a side panel fan (Antec 300 case).
And can this thread stay unlocked for a day longer so I can post what happens afterward? : D
markusaurileus
215
Ok, I swapped out the first board with a fresh one. Same model P8Z68-V LE.
I have to trust that the monitor was/is working correctly because the temps are in the same rough range (79-90°C). So a side-panel fan should help? I still can't physically tell what's up because it's absolutely cool inside, and the Z68 HS is lukewarm.
Also, how will a hot z68 chipset affect my performance? I'm planning on overclocking in the next week.
I think u will not notice any difference in the performance : )
How many fans do u have going?
I had an small issue with temp of the HDD's. I have 8 of them in.
Temps were 38°C-43°C. After increasing the pressure of incoming air by increasing the Antec fan speed to level 2, it went down to 28°C-31°C.
So, yes it would help tremendously, if u can point one right in.
