I just finished building a new PC into an existing Cooler Master Storm Scout 2 case that I had. The build went fine with no major issues.
I now want to be able to turn all the LED's built into the case fans on/off with the button provided on the case.
If you are not aware, this case has a button beside the power and reset buttons that fuctions as a switch to turn the LED's of the 2 front panel fans on/off while the fans still spin. It only fuctions for the LED's. However, I would like this button to function for all 6 case fans LED's rather then just the 2 on the front panel.
Here is the cooling setup I have:
http://ca.pcpartpicker.com/list/JPgbvV
Will this accomplish the task?
http://www.frozencpu.com/products/image/14674/ele-1000.jpg/ele-1000/2-Pin_Power_Distribution_PCB_8-Way_Block_MMT-PCB-2-82.html
If so, what other cables do I need?
Thanks in advance.
Thanks in advance.
