Is the ink out? Re-seat the cartridges if they should be OK. You can try to run the printer though a cleaning cycle also.
If you got 3rd party replacement cartridges, try it with regular HP ones, or just replace the printer, it's cheaper than new ink 🙂 Literally. WalMart has it for $24.
