How Connect Front Panel to Motherboard
The only thing I see is the audio. That should be obvious. The front panel pins should be to the right side of the board and out of the picture. The pins should be marked on the board. Plus you can probably download a PDF of the MB manual at the board web page. The connectors from the front panel should have the "positive" marked on them. It all should be marked on the MB.
In classic motherboard is correcct that you say but this motherboard is designed for a different use has nothing of what . originally mounted on a particular case , as soon as the power supply provides power turns on and the only button this is reset . There is no light for PowerLEDs but only for HDLED .
The only manual that indicates that there are pins on the card is inserted by me in the link ..
How can I figure out where to connect everything ?
Thank You
