This is more of a general question and seeing peoples experience of being able to fix PC's. I couldnt really find a 'general' discussion thread so if it needs to moved to a more appropriate area then feel free ![Smile :) :)](/data/assets/smilies/smile.gif)
How did you learn about PC's, fixing them, removing/installing the components, learning about different components etc?
My Experience
I learnt from my PC having issues, usually once a year!. Each year one component would either break / have issues / or need to be upgraded!! Now sure if this is a good way of learning, because it caused me lots of stress each year, when something would break or a problem would arise.
First 2 years of owning my PC was fine...then it all changed...
1st ever issue (GPU): Graphics card broke, although I didnt know this and paid a PC repair man £60!! just for him to come round on his moped, go to my room, check a wire and say "yup its your graphics card"...£60 down the drain!? Removing the old GPU and installing the new one was really nerve-wracking at the time, but now seems really simple and easy![Smile :) :)](/data/assets/smilies/smile.gif)
2nd issue (Fans): PC temp / cpu (I think) would reach around 100ºC when gaming (e.g bf3)!! I had the standard intel stock cpu cooler and 1 pre-instilled fan at the front of my PC. I didnt even know about adding more fans to keep a PC cool. I had to learn about removing the CPU and adding a new one, as well as connecting case fans. This made me slightly more confident with PC's as I applied glue, put together the Noctua fan, got it working etc
3rd issue (Storage) This year it was storage. I had defragging that would take forever, had some errors/issues with my PC so was advised to 'flash' my BIOS and reinstalling Windows 10. As also advised, it was a good opportunity to buy an SSD. So I successfully did all that, after many questions/tutorials/consideration and I think everything seems to be fine now
I have learnt a lot over the years, I cleaned my PC out with air-duster in the summer, and felt confident removing wires/components, cleaning it all and getting stuck 'in there'. I can understand how fixing PC's can be a hobby for people
Now lets see what breaks next year... 🙁 Hopefully all is good from now on
What are your stories? Does anyone have it similar to me? Would be great to hear!
My Experience
