How do I activate built in ZIP
  • Thread starter Thread starter Guest
  • Start date Start date
Archived from groups: microsoft.public.windowsme.general (More info?)
To add the ability to create and open zipped files, or as Microsoft call
them - compressed folders:
Control Panel | Add/Remove Programs | Windows Setup, select System Tools
and click Details and then check the box alongside "Compressed Folders",
then click OK and Apply.
If you have already installed Win Me's compressed folders and they no
longer appear to work try re-registering zipfldr.dll as follows:
Start, Run and enter in the box
REGSVR32 ZIPFLDR.DLL
and then click OK. If that fails then uninstall compressed folders (see
above) and then reinstall.
Mike Maltby MS-MVP
mike.maltby@gmail.com
News reader <someone@not.here> wrote:
> or restore it.
> Thanks ppl.
Mike.. In reading this thread , and having compressed files myself I looked
into the directions provided by you. Went to Systems Tools and found:
Accessibility Options and Accessibility Tools , no "Compressed Folders".
> Mike Maltby MS-MVP
> > or restore it.
> > Thanks ppl.
Also, how will I know if it is installed. thanks boni
> > Mike Maltby MS-MVP
> > > or restore it.
> > > Thanks ppl.
Thanks Mike
Cheers :)
"Mike M" <No_Spam@Corned_Beef.Only> wrote in message
news:OqeZfuwJFHA.2628@tk2msftngp13.phx.gbl...
> Mike Maltby MS-MVP
> > or restore it.
> > Thanks ppl.
Glad to be of some help. I hope you get your compressed folders working
correctly.
Cheers,
Mike Maltby MS-MVP
> Thanks Mike
Boni,
I didn't say to look in the section "Accessibility" but instead said
select "System Tools" and then to click Details and then check the box
alongside "Compressed Folders", then click OK and Apply. Are you sure
you're looking in the right place?
http://www.microsoft.com/windowsxp/expertzone/meetexperts/nichol.mspx
In memory of a very dear friend, Windows MVP Alex Nichol
Mike Maltby MS-MVP
> I looked into the directions provided by you. Went to Systems Tools
> and found: Accessibility Options and Accessibility Tools , no
I know what happened....Boni has to highlight "System Tools" first. The
highlighter was on the first option "Accessibility" when Details was first
clicked.
Bart
news:eKlqZuzJFHA.2764@tk2msftngp13.phx.gbl...
> Boni,
> Mike Maltby MS-MVP
Looked in the wrong area. I got it now, also noted that Compressed Files was
already selected. Thanks.... Mike and Bart too. Is it safe to just right
click and delete some of the picture files. Others are Spybot & Destroy like
DSO, Gain etc.
boni.
"Mike M" wrote:
> Boni,
> Mike Maltby MS-MVP
