How do I add another fan to my CPU Cooler?
IAmTheTofu
1,024
Hey guys,
I have 4 questions.
1. Will adding another fan to my heat-sink improve my temps? If so, by how much?
2. Which direction will I need to put it?
3. Where can I find the fans? I'm looking to spend maybe 10 dollars at most. Cheaper is better.
4. How would I install it?
Thanks
A normal 120mm case fan will work although you may want something allittle better like some of the brands mentioned above or order the same fan from cryorig . The two fans can be connected with a 4 pin "Y" connector to the motherboard so both fans can be controlled by cpu temps reported. Try to use two indentical fans.
Would normal case fans work too?
