low speed fps is going from 3-5 and sometimes 5-10 help me please
Sounds as if the laptop's GPU is not up to coping with your Game's graphics, and laptops are mostly impossible to upgrade
without buying a better one...Occasionally the BIOS will allow an upgrade from an AMD A6 to an AMD A8 for a marginal improvement...
Post your Laptop details for more accurate advice...
No chance, I'm afraid! Best try to buy an HP Laptop, no older than a DV6-6000 series, preferably with an Intel CPU and HD6770M GPU. Units with an i3 can be bought relatively cheaply, then you can upgrade to an i5 or i7, but ensure that you get the correct heatsink/fan....
