Question how do i change the speed of a 3 pin fan
aidanwright24
Commendable
Jan 3, 2019
28
I know you have to change the voltage for the fans to change speeds but how. i only have 2 headers (1 3pin 1 4pin) do i need a controller? can i use bios or software?
What motherboard do you have? Its been a long time since I've seen a motherboard with a 3 pin fan header, they are all 4pin PWM nowadays
But yes in the BIOS you should be able to set the fan curve for each header.
Ab350m (not pro4 or anything) and when im in the bios i can only change chassis fan 1 which is the pwm one and not the 3 pin from what i can see
Make sure the other fan is in DC/ Voltage mode and not Auto or PWM. That should allow you to change the fan curve then.
Only problem is i dont see anyway of accessing the 3pin fan settings.
In the H/W Monitor it has usual cpu temp, mobo temp and all that then it says chassis fan 1 speed at 1200rpm (the pwm header) then chassis fan 2 speed at 1500rpm (3 pin) then it says a bunch of voltage things below that but i cant interact with them. The only things it lets me change with the fans are the cpu fan, chassis fan 1, over temp protection and open case feature
Sorry I edited my statement after I read the manual for your mobo
Did some research it appears your mobo doesnt support 3pin fan control. You will either need to get a fan controller, or more simple and cheaper get something like this https://www.amazon.com/Noctua-NA-SRC10-Accessory-Low-Noise-Adaptors/dp/B00KG3KELQ
You can look around but basically those cables are either called low noise or resister cable adapters.
Only two I know of and I don't know how 3 pin fan control works with them. Personally I only have 2 fans ( 200mm on the front and 140mm on the back) on my case, and it provides more then enough air flow.
https://www.amazon.com/Phanteks-Uni...ords=cpu+fan+controller&qid=1580159161&sr=8-8
https://www.amazon.com/SilverStone-...ords=cpu+fan+controller&qid=1580159161&sr=8-5
Do you think i could return the fans i bought and get pwm fans instead (i got them on saturday)pwm just seems so much easier and straight forward
