How do I check to see if the motherboard I'm getting works? I don't have a cpu that works with it, so how am I supposed to check before I get the cpu or before the last return day? Thanks for any suggestions!
In my experience if you get a beep code from the Motherboard it is a good indicator that it works.
hook up a speaker to the front panel connector and turn it on, without a CPU the motherboard will beep, without ram the motherboard will beep. no beep no good
