[SOLVED] How do i connect a 4-pin rgb connector to a 5-pin mobo header ?
Jun 28, 2021
My Aorus B450 M has a 5 pin RGB header while my Cooler Master ML120L AIO cooler has a 4 pin connector. It is a 12 v. How do I attach it and is it possible to use RGB Fusion ?
hi, first 4 pins are for normal RGB (+12V,G,R,B), 5th pin is for extra white channel, its not necesary to use 5pin rgbw led strips, 4pin rgb is supported
if ure affraid of it, there is near CPU 4pin RGB connector (led_cpu) which you can use
