[SOLVED] How do I connect case fans?
Aug 16, 2019
6
Hello all!!! I have a XPG Battlecruiser case and a ASUS Z390-A motherboard. Just wondering how do I connect the ARPG case fans to the motherboard?
There's a built in RGB controller, the RGB 4pin from the fans should go to it, also needs a Sata power plug. Not sure if the fan wires can also go to it, you'll have to read the manual or the back of the fans for the amperage, they are 3pin DC, so may or may not go on a splitter or require a hub. Worst case scenario, there's plenty of available fan headers on the motherboard to run 2 to one header and the third to another header.
